> For the complete documentation index, see [llms.txt](https://apps.developer.homey.app/llms.txt). Markdown versions of documentation pages are available by appending `.md` to page URLs; this page is available as [Markdown](https://apps.developer.homey.app/the-basics/devices/pairing/system-views/oauth2-login.md). Agents can also search and read this documentation through its [MCP server](https://apps.developer.homey.app/~gitbook/mcp).
# OAuth2 Login
This view can be used for devices that need OAuth2 authorization. When it's successful, it will automatically proceed to the next view.
**Usage:** `"template": "login_oauth2"`
{% hint style="warning" %}
The example below is for completeness only. Pleaser read [OAuth2](https://apps.developer.homey.app/cloud/oauth2.md) to learn how to integrate with OAuth2 APIs the easy way.
{% endhint %}
{% code title="/drivers/\<driver\_id>/driver.compose.json" %}
```javascript
  "name": { "en": "My Driver" },
  "images": {
    "small": "/drivers/my_driver/assets/images/small.png",
    "large": "/drivers/my_driver/assets/images/large.png"
  "pair": [
      "id": "login_oauth2",
      "template": "login_oauth2",
      "options": {
        "hint": "Login with your credentials",
        "button": "Log-in"
      "id": "list_devices",
      "template": "list_devices",
      "navigation": { "next": "add_devices" }
      "id": "add_devices",
      "template": "add_devices"
{% endcode %}
## **Options**
| Key        | Type        | Default | Description |
| `title`    | [translation object](https://apps.developer.homey.app/the-basics/app/internationalization.md) |         |             |
| `subtitle` | [translation object](https://apps.developer.homey.app/the-basics/app/internationalization.md) |         |             |
| `hint`     | [translation object](https://apps.developer.homey.app/the-basics/app/internationalization.md) | `""`    |             |
| `button`   | [translation object](https://apps.developer.homey.app/the-basics/app/internationalization.md) | `""`    |             |
When either `hint` or `button` are set to a value, a button will appear and wait for the user to click it before opening the popup.
{% tabs %}
{% tab title="JavaScript" %}
{% code title="/drivers/\<driver\_id>/driver.js" %}
```javascript
const Homey = require("homey");
const API_URL = "https://api.myservice.com/oauth2/authorise?response_type=code";
const CALLBACK_URL = "https://callback.athom.com/oauth2/callback/";
const CLIENT_ID = Homey.env.CLIENT_ID;
const OAUTH_URL = `${API_URL}&client_id=${CLIENT_ID}&redirect_uri=${CALLBACK_URL}`;
class Driver extends Homey.Driver {
  async onPair(session) {
    const myOAuth2Callback = await this.homey.cloud.createOAuth2Callback(OAUTH_URL);
    myOAuth2Callback
      .on("url", (url) => {
        // send the URL to the front-end to open a popup
        session.emit("url", url);
      .on("code", (code) => {
        // ... swap your code here for an access token
        // tell the front-end we're done
        session.emit("authorized");
module.exports = Driver;
{% endcode %}
{% endtab %}
{% tab title="TypeScript" %}
```mts
import Homey from "homey";
export default class Driver extends Homey.Driver {
  async onPair(session: Homey.Driver.PairSession): Promise<void> {
    const myOauth2Callback = await this.homey.cloud.createOAuth2Callback(OAUTH_URL);
    myOauth2Callback
      .on("url", (url: string) => {
      .on("code", (code: string) => {
        session.emit("authorized", undefined);
{% endcode %}
{% endtab %}
{% tab title="Python" %}
{% code title="/drivers/\<driver\_id>/driver.py" %}
```python
import asyncio
from homey import driver
from homey.homey import Homey
from homey.pair_session import PairSession
OAUTH_URL = f"{API_URL}&client_id={CLIENT_ID}&redirect_uri={CALLBACK_URL}"
class Driver(driver.Driver):
    async def on_pair(self, session: PairSession) -> None:
        my_oauth2_callback = await self.homey.cloud.create_oauth2_callback(OAUTH_URL)
        def on_url(url: str):
            # send the URL to the front-end to open a popup
            asyncio.create_task(session.emit("url", url))
        def on_code(code: str | Exception):
            # ... swap your code here for an access token
            # tell the front-end we're done
            asyncio.create_task(session.emit("authorized"))
        my_oauth2_callback.on_url(on_url)
        my_oauth2_callback.on_code(on_code)
homey_export = Driver
{% endcode %}
{% endtab %}
{% endtabs %}
