Skip to content
For the complete documentation index, see llms.txt. This page is also available as Markdown.
Custom Pairing Views
Most drivers will suffice using the provided pairing templates. Some advanced drivers however can benefit from creating their own views.
The pairing views consists of .html files in the /drivers/<driver_id>/pair-folder. Where the name of the file is the view ID, as id described in the App Manifest.
The pairing views have a few Homey-specific JavaScript functions available. They are documented below.
Back-end API
The session property passed in onPair can control the front-end programmatically.
/drivers/<driver_id>/driver.js
const Homey = require('homey');
class Driver extends Homey.Driver {
  async onPair(session) {
    // Show a specific view by ID
    await session.showView("my_view");
    // Show the next view
    await session.nextView();
    // Show the previous view
    await session.prevView();
    // Close the pair session
    await session.done();
    // Received when a view has changed
    session.setHandler("showView", async function (viewId) {
      console.log("View: " + viewId);
module.exports = Driver;
Front-end API
The following methods are available at the front-end to communicate with the back-end. The Homey object is globally available.
Emit an event
Homey.emit( String event, Mixed data ): Promise<any>
Emit an event to your app. The function called will be the one registered by session.setHandler( String event, Function callback ) in your driver implementation.
Receive an event
Homey.on( String event, Function callback )
Listen to a message from your app. You can trigger this function from your app by calling session.emit().
Set a Title
Homey.setTitle( String title )
Set the window's title.
Example
Set a Subtitle
Homey.setSubtitle( String subtitle )
Set the window's subtitle.
Example
Show a View
Homey.showView( String viewId )
Navigate to another view. The parameter viewId should be an ID as specified in your App Manifest.
Previous View
Homey.prevView()
Show the previous view.
Next View
Homey.nextView()
Show the next view.
Get the current view
Homey.getCurrentView()
Returns the current view ID.
Create a device
Homey.createDevice( Object device ): Promise<Object>
Create a device with the properties in device.
The device object must at least contain the properties data and name and may contain icon, class, capabilities, capabilitiesOptions, store and settings.
Example:
Get current zone
Homey.getZone(): Promise<string>
Get the Zone ID of the active Zone. The promise resolves to the zone id.
Get view options
Homey.getOptions( [String viewId] ): Promise<Object>
Get the options of a view, or the current view when viewId is omitted. The promise resolves to the viewOptions of the specified view.
View options may be added to a view by specifying an options object in the App Manifest.
Set navigation close
Homey.setNavigationClose()
Remove all navigation buttons and show a single Close button.
Homey.done()
Close the pairing window.
Alert dialog
Homey.alert( String message[, String icon] ): Promise<void> Show an alert dialog. The second parameter icon can be null, error, warning or info.
Confirm dialog
Homey.confirm( String message[, String icon] ): Promise<boolean> Show a confirm dialog. The second parameter icon can be null, error, warning or info.
The promise will resolve to true when the user pressed OK.
Homey.popup( String url ) Show a popup with a remote website.
Internationalisation
Homey.__( String key [, Object tokens] )
Translate a string programmatically. The first argument key is the name in your /locales/__language__.json. Use dots to get a sub-property, e.g. settings.title. The optional second argument tokens is an object with replacers.
Within your custom views, you can also use translations. For example:
Read more about translations in the internationalization guide.
Show the loading overlay
Homey.showLoadingOverlay()
Shows the loading overlay.
Hide the loading overlay
Homey.hideLoadingOverlay()
Hides the loading overlay.
Get a view's store value
Homey.getViewStoreValue( String viewId, String key ): Promise<any>
Get's a view's store value. Promise will resolve to the requested value.
Set a view's store value
Homey.setViewStoreValue( String viewId, String key, Mixes value): Promise<void>
Set a view's store value.
Example
Last updated
Was this helpful?
