Capabilities
A capability is a programmatic representation of a device's state.
A simple example of capabilities is onoff
. This is a boolean capability that tells Homey whether the device is turned on
(when true
) or off
(when false
). Homey ships with many capabilities (called system capabilities). These can be found in the Device Capability Reference.
Using capabilities
In your App Manifest, for every driver an array capabilities
is required. This is an array with the keys of all capabilities. This array can be overwritten during pairing.
Your Device (device.js
) instance needs to keep the device synchronised with Homey. Capabilities need to be synchronized both ways. This means that if a device's state changes, for example if the user turns on the lights, your app needs to tell Homey. It is also possible for Homey to request your app to change the state of the device, for example when a Flow is triggered to turn off the lights.
Your Device
class should listen for changes to the device's and then update the capability value within Homey by calling Device#setCapabilityValue()
. You should also register a method with Device#registerCapabilityListener()
that to update the state of the physical device.
Capability options
Some capabilities make use of capability options, which can be set to change the default behaviour of capabilities. Capability options can be set using the capabilitiesOptions
object in the driver's entry in the App Manifest.
Options that apply to all capabilities are:
Attribute
Description
title
Overwrite the capability title { "en": "My Custom Title" }
Make sure a custom title is never more than 2 - 3 words.
preventInsights
Prevent Insights from being automatically generated.
preventTag
Prevent a Flow Tag from being automatically generated.
Duration
The duration capability option can be used to allow users to specify the duration of a Flow Action card for built-in capabilities. The configured duration will be passed as a second argument to your capability listener in Device#registerCapabilityListener()
Attribute
Description
duration
Set to true
to allow users to set a duration on the Flow Action card associated with this capability.
Boolean capability options
Options that apply to boolean capabilities, such as onoff
, windowcoverings_closed
, garagedoor_closed,
alarm_generic
and button
, are:
Attribute
Description
insightsTitleTrue
insightsTitleFalse
titleTrue
titleFalse
Number capability options
Options that apply to number capabilities, such as the measure_*
capabilities, are:
Attribute
Description
units
decimals
The number of decimals to show in the UI.
min
A minimum for the capability value.
max
A maximum for the capability value.
step
A step size of the capability value.
Enum capability options
Options that apply to enum capabilities, such as the thermostat_mode,
are:
values
Note that these are only available since Homey v12.0.1 so in order to use this option increase your app's compatibility.
Zone activity capability options
Certain capabilities will mark their device's zone active when their value changes. This behaviour can be controlled using capability options.
Options that apply to alarm_motion
, alarm_contact
, alarm_vibration
, alarm_occupancy
and alarm_presence
are:
Attribute
Description
zoneActivity
Controls whether changes to this capability value also trigger the zone to become active. Set to false
to disable zone activity for this capability.
Homey Energy capability options
Options that apply to measure_power
are:
Attribute
Description
approximated
Light device capability options
Options that apply to onoff
are:
Attribute
Description
setOnDim
Getable
and volume_mute
are:
getable
This capability option can be set to false
to make the onoff
or volume_mute
capability stateless. If this option is set to false
the device's quickAction
will be disabled, the UI components will be updated, and some Flow cards will be added/removed.
Custom capabilities
In some cases these might not suit your device. Your app can provide additional capabilities (called custom capabilities).
Define custom capabilities in your App Manifest, in an object capabilities
The following options can be set for all custom capabilities:
Property
Description
type
A capability can be of type boolean
, number
, string
or enum
title
getable
setable
Default: true
, a boolean whether the capability's value can be set by a front-end. When setable is false
, your Device doesn't need to register a capability listener.
units
uiComponent
A preferred component to display in the UI. To hide a capability in the UI, set uiComponent
to null
icon
A path to an .svg
Icon.
insights
Default: false
, whether this capability should create an Insights log. Only applicable to the number and boolean type.
When the capability type is boolean
the following additional properties can be set:
Property
Description
uiQuickAction
Set this to true when you want the user to quick-toggle the capability's value from the UI.
insightsTitleTrue
insightsTitleFalse
When the capability type is number
Property
Description
min
max
step
decimals
When the capability type is enum
Property
Description
values
Device Indicators and Custom Capabilities
The Homey web app and mobile app can display indicators next to the device icons. This gives users the ability to view a specific capability, such as a temperature value or battery status, at a glance. Custom boolean and number capabilities can also be shown as indicators as device indicators.
Boolean Capabilities
Boolean capabilities, also called Alarms in Homey, are displayed in two different ways if they start with the prefix alarm_
. By default all capabilities with this prefix are grouped, and a warning icon is shown if the value of any of the boolean capabilities is true
. Alternatively users can choose to show the indicator value of a single specific Alarm capability. The alarm_battery
capabilities will show an "empty battery" icon instead of an exclamation mark.
Number Capabilities
Number capabilities, are displayed as a numeric value together with the unit of the capability. Users are able to select capabilities that start with either the prefix measure_
or meter_
. The measure_battery
capability will always be displayed with a custom battery icon instead of a number.
Note that it's not possible for users to select and override the default indicator if the device class is thermostat, light, lock or speaker.
UI Components
All system capabilities have their own UI component. Custom capabilities can also use these UI components. Homey will automatically try to find the right component, but you can override this by specifying the uiComponent
property in your custom capability.
Toggle
"uiComponent": "toggle"
The toggle component displays one boolean
capability. Depending on the capability, the look might change.
Slider
"uiComponent": "slider"
The slider component displays one number
Sensor
"uiComponent": "sensor"
The sensor component displays multiple number
, enum
, string
or boolean
capabilities.
Booleans that are true
and begin with alarm_
will flash red.
Thermostat
"uiComponent": "thermostat"
The thermostat component displays a target_temperature
capability, and an optional measure_temperature
If you use sub-capabilities for target_temperature
and measure_temperature
, make sure the dot suffix of the capabilities are the same so that they will be displayed together, for instance: target_temperature.top
and measure_temperature.top
Media
"uiComponent": "media"
The media component accepts the speaker_playing
, speaker_next
, speaker_prev
, speaker_shuffle
and speaker_repeat
capabilities.
Additionally, it shows the album art as set using Device#setAlbumArt()
Color
"uiComponent": "color"
The color component accepts the light_hue
, light_saturation
, light_temperature
and light_mode
capabilities.
Battery
"uiComponent": "battery"
The battery component accepts either a measure_battery
or alarm_battery
capability.
Picker
"uiComponent": "picker"
The picker component accepts one enum
capability and shows a list of possible values. Make sure the values titles fit on one line and are never more than 3 words.
Ternary
"uiComponent": "ternary"
The ternary component accepts one enum
capability with three values, meant for motorized components.
Button
"uiComponent": "button"
The button component displays one or moreboolean
capabilities. Depending on the capability, the look might change. Most buttons are stateless but it is possible to add a stateful button if the capability is both setable
and getable
. Some buttons will be grouped together like volume_up and volume_down.
No UI component
"uiComponent": null
To hide the UI component, specify null
as value.
Maintenance Actions
This feature depends on Homey v3.1.0 and Homey Smartphone App v3.0.1.
Button capabilities can be flagged as maintenance action. This will show a button in 'Device settings > Maintenance actions' and hide the uiComponent
in the device view. When this button is pressed the registered capability listener will be triggered. This allows you to initiate actions from the device's settings.
Example use cases:
Starting the calibration process on a device
Resetting accumulated power measurements
Creating a maintenance action
A maintenance action capability must be a capability that extends the system capability button
. In order to mark it as a maintenance action add the maintenanceAction: true
property to the capabilitiesOptions
object of the driver manifest. Additionally, provide a title
property, and optionally a desc
property.
Listening for maintenance action events
Register the capability listeners in device.js
to listen for maintenance action events.
Sub-capabilities - using the same capability more than once
In certain cases it might occur that a device should use a capability more than once. You can use a sub-capability for this purpose.
An example would be a device with an outside and inside temperature sensor. Simply append a dot followed by an identifier after the capability string during in your driver, e.g. measure_temperature.inside
& measure_temperature.outside
Flow Cards will not be automatically generated for sub-capabilities, you should create these cards yourself.
Last updated
Was this helpful?
