Custom Pairing Views
Most drivers will suffice using the provided pairing templates. Some advanced drivers however can benefit from creating their own views.
The pairing views consists of .html
files in the /drivers/<driver_id>/pair
-folder. Where the name of the file is the view ID, as id
described in the App Manifest.
The pairing views have a few Homey-specific JavaScript functions available. They are documented below.
Back-end API
The session
property passed in onPair
can control the front-end programmatically.
Front-end API
The following methods are available at the front-end to communicate with the back-end. The Homey
object is globally available.
Emit an event
Homey.emit( String event, Mixed data ): Promise<any>
Emit an event to your app. The function called will be the one registered by session.setHandler( String event, Function callback )
in driver.js
Receive an event
Homey.on( String event, Function callback )
Listen to a message from your app. You can trigger this function from your app by calling session.emit()
Set a Title
Homey.setTitle( String title )
Set the window's title.
Example
Set a Subtitle
Homey.setSubtitle( String subtitle )
Set the window's subtitle.
Example
Show a View
Homey.showView( String viewId )
Navigate to another view. The parameter viewId
should be an ID as specified in your App Manifest.
Previous View
Homey.prevView()
Show the previous view.
Next View
Homey.nextView()
Show the next view.
Get the current view
Homey.getCurrentView()
Returns the current view ID.
Create a device
Homey.createDevice( Object device ): Promise<Object>
Create a device with the properties in device
The device
object must at least contain the properties data
and name
and may contain icon
, class
, capabilities
, capabilitiesOptions
, store
and settings
Example:
Get current zone
Homey.getZone(): Promise<string>
Get the Zone ID of the active Zone. The promise resolves to the zone id.
Get view options
Homey.getOptions( [String viewId] ): Promise<Object>
Get the options of a view, or the current view when viewId
is omitted. The promise resolves to the viewOptions
of the specified view.
View options may be added to a view by specifying an options
object in the App Manifest.
Set navigation close
Homey.setNavigationClose()
Remove all navigation buttons and show a single Close button.
Close the pair session
Homey.done()
Close the pairing window.
Alert dialog
Homey.alert( String message[, String icon] ): Promise<void>
Show an alert dialog. The second parameter icon
can be null
, error
, warning
or info
Confirm dialog
Homey.confirm( String message[, String icon] ): Promise<boolean>
Show a confirm dialog. The second parameter icon
can be null
, error
, warning
or info
The promise will resolve to true
when the user pressed OK
Popup
Homey.popup( String url )
Show a popup with a remote website.
Internationalisation
Homey.__( String key [, Object tokens] )
Translate a string programmatically. The first argument key
is the name in your /locales/__language__.json
. Use dots to get a sub-property, e.g. settings.title
. The optional second argument tokens
is an object with replacers.
Within your custom views, you can also use translations. For example:
Show the loading overlay
Homey.showLoadingOverlay()
Shows the loading overlay.
Hide the loading overlay
Homey.hideLoadingOverlay()
Hides the loading overlay.
Get a view's store value
Homey.getViewStoreValue( String viewId, String key ): Promise<any>
Get's a view's store value. Promise will resolve to the requested value.
Set a view's store value
Homey.setViewStoreValue( String viewId, String key, Mixes value): Promise<void>
Set a view's store value.
Example
Last updated
Was this helpful?
