App Settings
App Settings allow you to add custom HTML pages, that users can view to modify your app's settings. App Settings can be used for global configuration parameters for your app.
A Homey App can save settings that are persistent across reboots. These settings can be accessed from anywhere in your app through ManagerSettings
. You can also create a page where users can update the App Settings.
Creating an App Settings page
To create a settings view, create a folder named /settings/
in your app's root, and create a new file named index.html
in it.
Include the following script in your <head>
Next, add a function called onHomeyReady
The first argument of onHomeyReady
will be a Homey
instance, which can be used to communicate with Homey.
Finally, call Homey.ready()
to show the settings view.
Example
Below is a simple example to save a username & password. Learn more about HTML usage and CSS styling.
Settings View API
Homey.ready()
Homey.ready()
The settings view will be hidden until this method has been called. Use the extra time to make required API calls to prevent flickering on screen.
Homey.get( [String name,] Function callback )
Gets a single setting's value when name
is provided, or an object with all settings when name
is omitted.
Homey.set( String name, Mixed value, Function callback )
Sets a single setting's value. The value must be JSON-serializable.
Homey.unset( String name, Function callback )
Unsets a single setting's value.
Homey.on( String event, Function callback )
Register an event listener for your app's realtime events. System events when modifying settings are: settings.set
, settings.unset
Homey.api( String method, String path, Mixed body, Function callback )
Make a call to your App's Web API. The first argument method
can be either GET
, POST
, PUT
or DELETE
. The second argument path
is relative to your app's API endpoint. The third argument body
is optional, and null
can be provided to ignore it. For example:
Homey.alert( String message, Function callback )
Show an alert dialog.
Homey.confirm( String message, Function callback )
Show a confirm dialog. The callback's 2nd argument will be true
when the user pressed OK
Homey.popup( String url[, Object opts] )
Show a popup (new window). The object opts
can optionally have a width
and height
property of type number
. The default width and height is 400
Homey.openURL( String url )
Show a new window.
Homey.__( String key [, Object tokens] )
Translate a string programmatically. The first argument key
is the name in your /locales/__language__.json
. Use dots to get a sub-property, e.g. settings.title
. The optional second argument tokens
is an object with replacers. Read more about translations in the internationalization guide.
Last updated
Was this helpful?
